Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-27-2005, 08:16 PM
grchdrvr grchdrvr is offline
desperately needing help
I would appreciate any help with the limited info I am able to provide. The problem (from what I am told) with my 96 JGC Laredo is that I need to replace the passenger side cv joint. Far from a mechanic myself I have a couple buddies doing the work. I bought the haynes manual but it apparently does not show the dismantling process, so if anyone could let me know where to find said info, or share personal knowledge, it would be greatly appreciated. Thank you.
Old 12-28-2005, 03:31 AM
ByronP ByronP is offline
It's pretty straight forward. Read this and just replace with standard replacement cv axle. The only part that's a b!tch are the three bolts holding the hub assembly on. Good luck.
http://www.4x4wire.com/jeep/tech/axle/weak_link
93 ZJ w/V8, BB and UC springs, 31" MTZs, ProComp MX6, FM50, DynoMax Cat, OME SD40, Electric fan conversion
Old 12-28-2005, 01:09 PM
Re: desperately needing help
Thank you very much, ByronP.
