Adding power to a 3.1 se
02 3.1 se with 82K. What can I do to improve performance?
Re: Adding power to a 3.1 se
It depends on how much you are willing to spend and availability of mods. There are aftermarket mods out there for the 3.1 but not as much as the 3800 so you wll be limited. I know the 3.4L which is similar takes to mods quite well. Checkout RSM Racing and PFYC.com.
RSM racing has an Air Induction System with K&N air filter...will this really work?
http://www.rsmracing.com/catalog.htm it's under grand prix, 3.1L |
Re: Re: Adding power to a 3.1 se
Another suggestion is to consider an overdrive pulley which replaces the stock crank pulley. Also, a hi-flow CAT convertor. Not sure about the 3.1L but DHP has re-programmed PCMs available. However, they provide custom programming on the 3.1L. Good luck!
