| Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models |
We are having problems fixing the brakes on a 92 olds 88, have changed the pads, brake line and caliber, but brakes are still dragging! I don't know what else to try, I even took the caliber back because I thought I had gotten a bad one, but still no luck
Re: Front Brakes 92 oldsmobile delta 88
Look for a crimped line between the master cylinder and the calipers. Rocks can sometimes kink lines. Or it's possible that the brake fluid has gelled up from old age, heat, or possibly from mixing types of brake fluid..I recommend flushing both front brake lines and adding fresh DOT3 fluid, if you don't find a kinked line. Also make sure the pad isn't dragging on the caliper.
2007 Certified DaimlerChrysler Service Technician... True blue GM at heart. |
In addition to the above, sometimes a faulty master cyl can cause the brakes to drag, especially after the brakes warm up a little.
After you back off the calipers they should be able to be slid side to side, if they don't, that very well could be your problem. Either the slides (that the blots go through) are stuck or you might have a rust buildup where the caliper rides. |
Another thing to look at is wether or not your flex hoses might be bad. now most everyone knows howto identify a faulty flex hose from the outside. However we have had problems with flex hoses weakening from the inside out, restricting fluid travel. This was a problem the we found mostly on F-bodies but it's a possibility to look into.
