Old 12-27-2005, 04:32 PM
Benjamin2005 Benjamin2005 is offline
Caps
well caps fill in all the missin sound you can get when u power subs midranges and tweeters from an amp - jus wanna know what kinda cap is gonna do its job
Old 12-27-2005, 05:35 PM
germanyt germanyt is offline
Re: Caps
caps do not do what you think they do. its a common myth that caps restore the power to the amp when it hits a large current draw. this is like 10 percent true. fact is, the cap discharges and while some voltage is provided, your alt still has to recharge the cap basically making it useless. the pupose of a capacitor is to smooth out voltage. it acts as an AC filter which is useful when you are using an inverter that takes AC and makes it DC. unless the inverter is extremely efficient, some AC will still get through. a capacitor is used to remove that AC. another purpose for a cap is to discharge a desired amount of power to acheive a goal. this is where people think they work in car audio. take a camera flash for example. the battery in a camera charges up the capactor, when you push the button the cap discharges giving the light bulb much more power than would normally be obtained from the battery alone. you can hear it charging back up after the flash, its that steady beep sound. but try pushing the button five times in a row. the flash will not go off five times. same with an amp. when your bass hits, the amp draws power from the cap but continues to power the subs without waiting for the cap to recharge, once again making the cap useless.
(2) RE SX 15s (www.reaudio.com)
~6.5^3 net @ 35 Hz (polyfilled to increse vol. & lower tuning to 32 Hz)
(2) eD Nine.1s (www.edesignaudio.com)
1 Optima yellow top (www.optimabatteries.com)
1 Optima red top
200 amp alt (www.dbelectrical.com)
eDead V1SE2 250 sq ft
Big 3 (1/0 awg)
Pioneer DEH-P650 (www.pioneerelectronics.com)
Infinity Reference 5 1/4 comps (www.infinitysystems.com
Infinity Kappa 6x9s
MTX Thunder 3404
Power Acoustik TFT/LCD
Pyle DVD/CD/MP3/WAV/WMA player
Old 12-27-2005, 05:38 PM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
Re: Caps
kick the cap. buy a better alternator.
Old 12-27-2005, 06:13 PM
Re: Caps
i like jets idea
1 Optima red top
Big 3 (1/0 awg)
Infinity Kappa 6x9s
MTX Thunder 3404
