Old 12-27-2005, 12:00 PM
GPme GPme is offline
Rear License Plate BULB Replacement
I was recently the recipient of a WARNING by one of my county's "finest" advising me that my license plate light was out.
I just puchased a 2 bulb replacement pace to Advance Auto Parts for a few bucks, but, for the life of me, can't figure out how to get to the existing bulb/bulbs to replace.
There seems to be a small plastic, somewhat clear, cover over the middle of the plate, however, it does not seem to be EASILY removed? There are also two nuts one either side of the plastic, somewhat clear, cover, but they don't seem to be associated with BULB REPLACEMENT?
Anyone have any advice on changing my rear license plate light bulb to keep me from GOING TO JAIL before the next county mounty stops me?
I ran a search on threads, but, I suspect that this problem is much too easy and there has been no need for any assistance, so I could'nt find a related thread.
I'v got a 97 GTP with 201,800 MILES, still runs strong, but needs this bulb replaced!
Thanks,
GTPme
Old 12-27-2005, 12:17 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Rear License Plate BULB Replacement
Remove the two screws on each side of the lens, which will allow you to pull the assembly out and gain access to the bulb to replace it.
Old 12-27-2005, 01:03 PM
Re: Re: Rear License Plate BULB Replacement
THANKS richtazz:
Worked like a charm. Didn't actually need to remove the bolts/screws, only need to loosen and assembly was loos enough to remove. The bulb assembly twisted from the cover. I used masking tape to cover the bulb to aid in removing "just the bulb". Snaped new bulb in and replaced all.
Next project, replacement of my compressor's coupler. Yea right, I'll buy the part and have someone who's more mechanically inclined install it.
Thanks again for your help.
GPme
Old 12-27-2005, 02:55 PM
BIG-L's Avatar
BIG-L BIG-L is offline
Here are some great instructions for replacing the coupler in the snout.Click Here and great pictures also
~Larry~
