Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 12-27-2005, 11:58 AM
Silly1s Silly1s is offline
98 Durango Stalling
My 98 Durango will start after sitting for a few day, but after driving less than a mile it will stall without warning. It used to start after about 30 minutes, but now it won't start at all. It will crank, but not start. No check engine light is on. Please help me...
Old 12-29-2005, 09:09 PM
PopKorn PopKorn is offline
Re: 98 Durango Stalling
I'd start with a fuel filter.
Check the battery connections.
Check the fluid levels.
Upgrade the AAA.
81 Toyoduh diesel PU
87 Nissan Sentra SE Coup
97 Neon Nurple 4dr
98 Durango SLT Plus 4wd
Old 04-15-2006, 04:54 PM
TracyH68 TracyH68 is offline
I was told it was the fuel filter by many people, it wasn't. It was the crank shaft sensor. After replacing it it worked for a month or so then started doing the same thing again. I replaced the IAC valve and it again worked great for about a month or so and started doing the same thing. I eventially traded it. Good luck to you.
Old 10-17-2007, 03:53 AM
BigDudu BigDudu is offline
I am thinking this is the only way to solve problems on this car.
Old 11-09-2007, 11:19 AM
nkmn nkmn is offline
after reading many posts, we went to our mechanic and had him replace the pcm because our 98 started stalling too. PCM replaced...... have had no problems in several months. Dont go through all the other sensor replacemnts and such that they suggest it could be.... pcm should be your fix. If you have any questions let me know.... [email protected]
Old 12-12-2007, 07:52 PM
DoubleC DoubleC is offline
Its the Idle air control motor! just had work done at a shop
