Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 12-27-2005, 11:53 AM
SKYCHEN5 SKYCHEN5 is offline
95 Conv Problems
Hi everyone. I have been reading all the prev post and have learned a lot. Now i need help. the rear elec windows in my 95 conv dosn't move. one window is closed but the other is down. could you tell me where the fuse and switch is for these windows are. also does the conv top have a fuse and if so where is it located my top doesn't move either, my guess is the motor but i want to make sure of everything first.
thanks for your help
joe
Old 12-27-2005, 04:42 PM
94LebConv3La604 94LebConv3La604 is offline
Re: 95 Conv Problems
The fuses for both of those are with the rest behind your kick panel...if none of those are bad then it's a pretty safe guess it's the motors. I know that's the problem with mine heheh. I'm still paying off the transmission, tho, so no new window motor for a while. I'm just going to take out the hydraulics for the top when it gets warmer.
Old 01-04-2006, 02:28 PM
Re: Re: 95 Conv Problems
Thanks for the info i will try that. Also like you said if i cant find a cheap motor for the top i will take out the hydraulics.
Old 01-04-2006, 09:28 PM
Boogieman142 Boogieman142 is offline
Send a message via AIM to Boogieman142 Send a message via MSN to Boogieman142 Send a message via Yahoo to Boogieman142
The motorsin the convs.are known to go bad, so are the headlamp doors, what I would suggest for the wintertime is open the doors and then unplug the motor so they stay open, unless you park your car in a heated garage then I suggest you undercoat the whole car real good, when it is warmer your carrusts out quicker
