Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-27-2005, 05:40 AM
jagchick's Avatar
jagchick jagchick is offline
Send a message via AIM to jagchick
Stalling at Stops
My 98 has begun to kill at stops with no warning (no noise or low idle). I just replaced the fuel pump, spark plugs and wires, and FPR. I had a GM dealer diagnose it for codes and nothing came up (that was the only day it decided NOT to die on me). It usually only dies a couple times a day in the beginning of the day and only after I have been stopped idling for 5-30 seconds. I was going to have a mechanic replace the crankshaft sensors, but finally his scanner picked up 5 codes, 4 of which had to do with the transmission (only picked up the codes after it died). He thinks it is some kind of solenoid in the tranny that has gone bad because there is a solenoid that is known to cause the car to stall at stops. The car drives and shifts perfect, it just stalls at lights after being warmed up for 10+ minutes. If anyone has experience with this please tell me. My dealer repair manuals are on their way but I don't know if this issue is in them. I am wondering how many labor hours a shop will charge and how much the part is.
Old 01-02-2006, 07:38 PM
TRA RIV TRA RIV is offline
Re: Stalling at Stops
HI MY 99 DID THE SAME THING,IN THE WAY I PUT IN A CAN OF OCTANE ENHANCER AND A BOTTLE LUECUS FUEL SYSTEM CLEANER FOR TWO FILLUPS SO FAR IT STOPED STALLING . GOOD LUCK
Old 01-03-2006, 10:59 AM
apollo7879 apollo7879 is offline
A dirty EGR valve will cause too much EGR flow at idle, rough idling & stalling at idle will occur.
The valve is located Drivers side near the firewall, remove the two screws ,remove and inspect the valve , if you haven't already.
Old 01-04-2006, 03:01 AM
jagchick's Avatar
Thank you apollo. I will have my mechanic look at the EGR valve and change the fuel filter. I took it to a tranny shop and they think it's the crankshaft sensors also. I'm pretty sure it's not bad gas because I run premium (sometimes plus), and I do a lot of highway driving. I just got the dealer repair manuals, so I will look at them too. I suppose if it is not the EGR valve I will go the crankshaft sensor route. Has anyone found codes that link to the sensors when hooked to a computer? When I want the car to die for the mechanic it won't, so his computer can't pick up any codes.
Old 01-04-2006, 11:53 AM
frs64 frs64 is offline
Re: Re: Stalling at Stops
My 96 had the same problem. The throtttle body butterfly was shutting off all the way. I had to replace the idle stop screw and open the butterfly a little and it quit stalling. Btw , the butterfly is what a lot of people call the thing that allows air into the intake.
Old 02-03-2006, 06:06 PM
Adiemus Adiemus is offline
my aurora used to do the same thing and the only time it did it was when I put regular gas in the car. I just put premium gas in it and it has run fine and had no more problems.
Old 02-08-2006, 10:52 PM
Rezarecter Rezarecter is offline
mine occasionally did the same thing, turns out i had coolant in the harness of my idle air control motor and it shorted out
Old 02-16-2006, 09:05 AM
CGinWTN CGinWTN is offline
When my crankshaft sensor went bad my tach whould go haywire just before the car stalled out. By haywire I mean the needle would jump around the gauge. If yours isn't doing that I would look somewhere else.
Old 04-27-2006, 03:26 PM
bugheman bugheman is offline
Cool Re: Stalling at Stops
My mom has 99. Same thing. New plugs, wires, same deal..
Have not tried the EGR valve thing yet, I will look into that.
OCTANE BOOST REALLY DID THE TRICK??
Peace and Love
Remember this is for mom.... help a bro out...
Obstacles are what you percieve when you forget to focus on what to achieve.
opcorn:
Old 05-04-2006, 10:52 PM
rafamoreno1 rafamoreno1 is offline
hey im having the same troubles and i just realized my lights brighten and and dims when i accelerate im thinking mi surge and stall problems is related to that ill buy a new tensioner will tell u if it was fixed
Old 05-01-2007, 12:43 PM
yes the belt and pùlley fixed it
now months have passed and again stalling
but the tach jumps just before the stall
y had arleady replaced crank sensor some time ago
any more ideas? im thinking fpr but would it make the tach jump?
Old 05-01-2007, 04:36 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Belated feedback. Sorry but please check the date and do not resurrect old threads. If you have a new or ongoing issues then start a new thread. Thread closed.
POSTING IN CLOSED OR OUTDATED THREADS:
If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread.
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
Timeslip 08/12/06
AF Community Guidelines
Closed Thread
