Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-27-2005, 01:50 AM
boyertownMidnight's Avatar
boyertownMidnight boyertownMidnight is offline
Send a message via ICQ to boyertownMidnight Send a message via AIM to boyertownMidnight Send a message via Yahoo to boyertownMidnight
is this a good fuel pump test?
okay i wanted to check and see if im getting fuel to my engine so i took off my return fuel line and stuck it in a cup, then i cranked my engine, and then looked inside of the cup and seen about 3 tee-spoons of gas...
does this mean my fuel pump is working?
Old 12-27-2005, 01:51 AM
Re: is this a good fuel pump test?
also the engine is a 4g63 non-turbo 2.0
Old 01-02-2006, 04:19 PM
blue94eagletalon blue94eagletalon is offline
to check your fuel pump.there is a little clip on your fire wall right behind your battery.kinda looks like a speaker connector...kinda.it is under the black relay and by the connector clip that dosent go anywhere. anyways get a wire and put it on your battery on the positive side and place the other end in the connector and listen for the fuel pump to pump.buy a chiltons book or somehing it talks about it in there.
