Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-26-2005, 10:31 PM
wenzel wenzel is offline
2002 ABS Light, where do I start?
My ABS light has been on for about a year now and I'm going to get to it finally. Where do I start? I've read some on here...someone said something about codes...how do you read ABS codes? Nothing popped up on the OBDII read, the Check Engine light is not on.
2002 3.2 V6 2WD
Thanks
Aaron
Old 12-26-2005, 11:20 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 2002 ABS Light, where do I start?
Check the fuse for starters.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 12-27-2005, 01:11 PM
rodeo02 rodeo02 is offline
There is a post floating around either here or plantetisuzu on how to retrieve ABS from the OBDII connector. You basically short two pins with a pc of wire and count the *flashes* of the ABS light. If your ABS light is on and ABS never activates, the system is probably without power or the ABS motor is shot.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 12-28-2005, 09:36 PM
Fuse is good, wiring and connectors look good. Light is on and steady and no pulsations noted during braking. I'm guessing the module near the fuse box on the pass side is the culprit.... is this an OEM only item or does someone know were I can get one cheap?
Thanks
Aaron
G/luck
Joel
Old 12-28-2005, 10:23 PM
Any ABS part will be dealer/OEM. You also have two wheel speed sensors up front and one on the rear axle + a ton of wiring under the truck. The only way to know exactly what is going on is two read the ABS codes with a fancy $$$$ code reader, or jumper the pins per that thread.
Joel
