Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-26-2005, 10:02 PM
CivicRacerX's Avatar
CivicRacerX CivicRacerX is offline
Send a message via AIM to CivicRacerX
Question Ticking only when cold
97 Rodeo, 140k miles, there is a loud tick at start-up which we've noticed as it started getting colder this year. It usually lasts 5 minutes or so and goes away shortly after the car reaches regular temp. I've read a lot about the traditional lifter issues, but it seems like that tick is typically constant while the engine is running. I have done regular dino oil changes since I bought the car in 99 w/about 30k miles. Am I looking at the beginning of the legendary lifter problem, or does this sound like something different?
96 Honda Civic Daily - H22 Swap
82 Renault R5 Weekend Runner - Nearly Stock
83 Renault R5 Track Car - 13:1 CR, Archer Cams
Old 12-27-2005, 12:17 AM
Ramblin Fever Ramblin Fever is offline
Re: Ticking only when cold
If it's only lasting until the engine warms up, sounds more like just a cold engine thing, which is completely normal in most every engine.
If you're running a 10w-30 oil viscosity, try 5w-30, it'll get to the lifters faster.
The sound you're hearing is typical of an oil not having reached the lifters on a cold engine, and/or an oil filter type that the engine doesn't like.
I doubt this is a serious lifter noise issue that others have experienced.
It could also be an exhaust leak, which is louder with a cold engine, and gets quieter as the engine warms up.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 03-31-2006, 12:51 AM
sollybro sollybro is offline
VALVE TRAIN TICKING SOUND ON 3.2L ISUZU ENGINES Valve Train Ticking Sound On 1992-98 Isuzu 3.2L EnginesRead this article regarding a valve train ticking sound on 1992-98 Isuzu 3.2L engines. One or more hydraulic lash adjusters do not fully extend due to varnish build up inside the adjusters. This condition results from exceeding the oil and filter change intervals on the vehicle. There are a couple of ways to possibly cure this problem that Isuzu offers. One of the simplest ways is changing the engine oil and filter using a 0W-30 synthetic engine oil prior to replacing any engine components. If the noise persists after those changes, refer to the following information. Once we have determined which bank the noise is coming from, the cylinder head valve cover needs be removed so that we can inspect each rocker arm for clearance at the valve tip. The noisy rocker arms are the ones with clearance when the rocker is on base circle of the cam and the valve is closed as shown in Figure 1. Note: Each cylinder head has an oil pressure relief valve that controls oil pressure to the rocker arms. If all rocker arms have clearance and/or the rocker arm pivot shaft is worn, then the cylinder head oil pressure relief valve may be stuck in the open position. Remove the rocker arm(s) that have clearance on them and inspect the wear pattern of the hydraulic lash adjuster surface contact with the valve stem as shown in Figure 2. Then remove the hydraulic lash adjuster from the rocker arms using your fingers. Do not damage the O-ring on the outside of the lash adjuster or replacement of the entire rocker arm is required. Insert a paper clip into the hole at the top of the lash adjuster and depress the spring loaded check ball while completely pushing in the piston at the opposite end. Some traces of oil may come out of the check ball hole. Carefully remove the O-ring and spray the lash adjuster piston with cleaner to remove any varnish while holding the piston open. Submerge in cleaning solvent with the check ball depressed and pump the piston repeatedly to allow the solvent to penetrate through the lash adjuster. Submerge the adjuster in clean 0W-30 synthetic engine oil with the check ball depressed and pump the piston repeatedly to allow the engine oil to penetrate through the lash adjuster. Then allow the piston to extend fully to fill the adjuster. Reinstall the O-ring and lube the rocker arm bore that houses the adjuster with 0W-30 synthetic engine oil, then push the adjuster back into place. Inspect for leaks at the check ball and piston by attempting to compress the adjuster without depressing the check ball.Good Luck!
Old 03-31-2006, 12:07 PM
redbug redbug is offline
If the ticking starts to continue when warm think about looking at the belt tensioner...
I had a 95 rodeo that had the valve tick from the day I took it off the lot. Brought it back to the dealer twice in the first month, they must have all been deaf. 208,000 miles later, same tick until the timing belt let loose, then the tick became a loud knock.....
Old 03-31-2006, 03:28 PM
ogfooman ogfooman is offline
just use a lighter weight oil. 5w-30 or 0w-30 might solve the prob.
