Go Back   Automotive Forums Car Chat > Mazda > 626/Capella/Capella Wagon
Old 12-26-2005, 09:42 PM
flery flery is offline
'95 trans fluid
can anyone tell me where you add transmission fluid on a 1995 mazda 626? i'm guessing it's this white-clear container near the engine...
Old 12-27-2005, 12:04 AM
kjbuente kjbuente is offline
Send a message via MSN to kjbuente Send a message via Yahoo to kjbuente
uuummmmm, dude.
almost all the containers near the engine are clear\white. And the answer is NO. You add your trans fluid though the dip stick, you'll need a funnel in order to get it though the tube. Now if it is a manual trans, you actually have to crwal under the car to find the fill plug. A local parts stor will tell you were to find it and how to tell if you need fluid.
If it ain't broken, Don't fix it!
Old 12-27-2005, 01:21 PM
Re: '95 trans fluid
yeah, my father made me feel stupid about all that. i almost put transmission fluid where the brake fluid goes. oops!
thanks anyway!
Originally Posted by kjbuente
uuummmmm, dude.
Old 12-27-2005, 09:27 PM
mazdatekchubyninja mazdatekchubyninja is offline
Re: '95 trans fluid
it uses dex / merc III in automatic and 70/90 syth oil in manual. in the autos do not overfill the level, make sure the car is running while checking level. If overfilled it will cause trans to overheat at high speed causing trans failure, then you're fucked.
