Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-26-2005, 07:35 PM
Teile Teile is offline
Send a message via AIM to Teile
Emergency break problems.
I have a 1993 isuzu rodeo stanard transmission and my emergency break stopped working about a week ago. Got into my car after my roommate had been driving it and it didnt work. My brother said something about a cable that needs tighting under the car but i cant seem to find one. Does anyone have any suggestions?
Old 12-27-2005, 03:07 PM
directory's Avatar
directory directory is offline
Re: Emergency break problems.
did you recently have snow or ice? sounds like a simple case of someone playing in a parking lot, sliding around...
there is a cable onder the truck, not exactly sure where on your year...
it will have a spinner nut on it that you need to tighten.
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 12-29-2005, 11:38 AM
highlandlake highlandlake is offline
Re: Re: Emergency break problems.
Originally Posted by directory
did you recently have snow or ice? sounds like a simple case of someone playing in a parking lot, sliding around....
Ha, sounds like you are familiar with the fun that can be had with a borrowed car. I used to do that years ago..........and your lucky if thats ALL that was wrong with the car.
I think that the brake adjustment is easier than climbing underneath. If this Rodeo has the center console, with the parking brake between the seats then all you have to do is remove the console cover and tighten the lock nut behind the handle (might be a 10mm wrench).
But this works only if the cable was over-stretched by a joyriding roommate. If there are more serious brake issues unrelated to the loan, well that means a trip to the brake shop.
Good luck - and uh, never beleive the line "I'll just use it to get us a pizza".
'65 Chevy Malibu SS
'06 Pontiac Vibe (a dead deer fits nicely in the back)
'04 Ford Escape
GMC S-15 4WD
'57 Chevy 210 post sedan
'51 Ford F2 pickup
Recently gone but not forgotten - 68 Chevelle, '97 Rodeo V6 4WD.
Old 12-29-2005, 12:10 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
You should adjust the rear brakes before messing with the cable. Shoes might have worn a bit.
With it on jack stands and parking brake off look at the back of the dust sheild for the brakes. There should be a rubber plug about 1/2"x1". Take it out and you should see a 'star' adjuster. While turning the wheel by hand turn the adjuster until the wheel will only make one complete revolution if you spin it then stop.
If the parking brake still doesnt work right after the rear brakes are adjusted, then adjust the cable. You should notice improved stopping performance once the rear brakes are adjusted.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 12-29-2005, 04:04 PM
directory's Avatar
Re: Re: Re: Emergency break problems.
Originally Posted by highlandlake
Ha, sounds like you are familiar with the fun that can be had with a borrowed car. .
who me???
SKYWARN
we be clubbin'
--B
Old 12-29-2005, 07:52 PM
Ramblin Fever Ramblin Fever is offline
You know, my emergency brake has never held the weight of the truck. Brake pads are fine, have only been replaced twice.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 12-30-2005, 06:51 PM
Gizmo42's Avatar
Mine does if I go one click past where you would think it should be (6th or 7th, I forget). Thats one problem with drum in disk for e-brakes. Its not a very big brake trying to hold a 4000+ lb vehicle. Mine didnt work at all until I adjusted them.
--Dave
Rear No-Slip Locker
