Old 06-08-2002, 07:41 AM
Bobj's Avatar
Bobj Bobj is offline
sandpaper grade
Just been polishing my Gtr with compound but still had orange peel, so i used some 1000 grade tamiya paper with water very gently, then back to compound now orange peel gone and i have a very nice shine on the bonnet. i was just wondering what grades of paper everyone else uses as i was going to get some 2000 grade paper to do the rest of the car cause i had to be bloody careful not to rub right through to the undercoat.
Old 06-08-2002, 08:07 AM
modelfan1's Avatar
modelfan1 modelfan1 is offline
Send a message via AIM to modelfan1 Send a message via Yahoo to modelfan1
I use a Micro Mesh polishing kit with grits up to 12000
I skip some in an effort to get done faster
Micro-Surface Abrasives
Mike:bandit:
Old age and treachery will overcome youthful exuberance everytime !!
Old 06-08-2002, 08:20 AM
daggerlee's Avatar
Mike, how long do you wait for the paint to cure before using Micromesh? And after 12,000 grit, do you still see any scratches in the surface of the paint? I have the same kit and only got good results on a die-cast car painted with automotive lacquer cured a month.
Dan
Old 06-08-2002, 10:58 AM
modelfan1's Avatar
I believe it depends on the lacquer for how long it takes to cure,Dupli-Color can be polished in 24 hours !
The 12000 grit should'nt leave anything but very faint marks which can be removed with the polish ! Are you keeping the surface and the paper
wet ?
:bandit: Mike
Old 06-08-2002, 02:03 PM
Wishmaster's Avatar
Wishmaster Wishmaster is offline
***** Lurker
Keeping the paper and surface wet.. Does that mean in a big bowl of water large enough to fit 2 hands and a model. and still possible to sand..???
Old 06-08-2002, 04:25 PM
daggerlee's Avatar
The 12000 grit should'nt leave anything but very faint marks which can be removed with the polish ! Are you keeping the surface and the paper wet ?
Yea, I wetsand with all the grits and I wash the model and the pad after each grit. The surface feels smooth as a baby's bottom but it still scatters light, and you can see small scratches/imperfections that the polish won't remove. It's been bugging me - the Testors was allowed to cure for 2-3 weeks and the Plastikote lacquer 2-3 days.
I haven't gotten good results on Testors Model Master spray-can and Plastikote spray-can. I'll stick with Duplicolor and Tamiya from now on.
Dan
Old 06-08-2002, 05:16 PM
modelfan1's Avatar
Well, you could do it that way but it would lead to dish pan hands !
Just dip the sand paper in water and wipe of excess plastic
:bandit: Mike
