Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 12-26-2005, 03:09 PM
BLK BUTY BLK BUTY is offline
Anybody Had these codes?
My daughter has a 92 88 Royale. She said it stalled several times the other day. I checked the trouble codes and this is what I found.
15 - Coolant Sensor Circuit
16 - System Voltage High/Low
22 - Throttle Position Sensor Circuit (Signal Voltage Low)
23 - Intake Air Temp (IAT) Sensor (Low Temp Indicated)
58 - Security System (Fuel Enable Circuit)
65 - Cruise Servo Position Sensor
67 - Cruise Switches Circuit
68 - Cruise System Problem
Anyone ever had anything like this? I've read thru a bunch of the old posts and I hven't seen a problem like this one mentioned. I know all the sensors can't be going bad at the same time. Think maybe the computer is going bad? I started it and let it run for about 20 minutes with no problmes then drove it about 10 miles and it did fine. Any thoughts or suggestions would be appreciated. Thanks.
Old 12-26-2005, 03:18 PM
maxwedge maxwedge is offline
A990 racer
Re: Anybody Had these codes?
Clear em' and see which ones come back as a starting point here.
Old 12-26-2005, 07:02 PM
Codes
Sorry, I forgot that part. I did clear them. They all came back. I'll try it again tho. Can't hurt. Thnaks for the response.
Old 05-19-2006, 12:06 AM
NoSpudsInIdaho NoSpudsInIdaho is offline
I know it's been a while since your posted your question, but I was wondering if you figured this out. My '92 88 Royale is having the exact same codes. Just started all of the sudden. Only stalled on my once, but am having very pronounced periods of reduced power while the dash computer is displaying warning messages and SES light is on.
Old 05-19-2006, 12:43 PM
mholman mholman is offline
Im having what sound like a similar problem on a 1994 Olds 88 Royale 6 cylinder. Im getting intermittant stalls. The speedometer goes wild, all the lights come on and the engine dies going down the road. (often after 15 miles of perfect driving) then I restart the engine going down the road and it runs about 3 miles and it happens again. Does anyone have any ideas what can be causing this??
Old 05-19-2006, 06:12 PM
olds8894 olds8894 is offline
Banned
Send a message via Yahoo to olds8894
My 94 was hacing similar problems but the only code that came up for me was "Cam Shaft Sensor- Signal Weak." Its abour 25 dollers for a new one and takes 5 minutes to replace. Try it.
