Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 12-26-2005, 11:24 AM
dakeenz dakeenz is offline
where is the obd plug 97 aurora ?backfiring
we are working on moms car and took car to auto zone or other and they can't find where to plug into 97 auroa low gas mileage and backfiring
Old 12-26-2005, 12:18 PM
Indy8's Avatar
Indy8 Indy8 is offline
Re: where is the obd plug 97 aurora ?backfiring
Molded port into the lower cover of the steering column, left of the steering wheel, all the way down.
Quality isn't expensive, it's priceless.
Old 12-29-2005, 09:47 PM
Canajun Canajun is offline
Poor gas mileage and backfiring could well be the coolant temp sensor--if you get a reading like "low coolant temp," that is definitely what it is. It basically chokes the engine by dumping more gas into it because it thinks that the engine temp is 30 degrees or so lower than it really is.
Old 12-30-2005, 02:21 AM
Indy8's Avatar
Hi... Are you confusing the low coolant sensor in the recovery tank with the incoming air temp sensor in the airbox? I thought the airbox sensor was the one linked to the enrichment circuit, but not positive.
