Old 12-26-2005, 09:43 AM
Gocart879 Gocart879 is offline
Fuel gauge acts weird
hello, recently i got an old lesabre, that i had to replace the fuel tank, sender, and pump. also the lines and brake lines. anyway when i gas up my vehicle the gauge goes past full, by about an 1/8 of an inch. when it starts dropping below that, it will stay at a certain level while stopped, and as i start moving, the gauge will move forward more towards full. what is causing this? the car runs great. also i have notices a few wires going to the tank, located at a section split in the very front section of the trunk. is this where i check for a bad ground? if i had a bad ground would my fuel pump still work?
Old 12-26-2005, 12:48 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Fuel gauge acts weird
You can learn to live with it, or replace it! (The sending unit) This post may help;
http://www.automotiveforums.com/vbul...e+sending+unit
Old 12-27-2005, 09:12 AM
i just dont understand how a brand new sending unit can be worn out. it did this since i installed it. is it possible this is a bad ground???
