Old 12-26-2005, 03:35 AM
love-less love-less is offline
using model masters metalizer
I recently bought a few metalizer laquers (both buffing and non-buffing) and i was wondering how to go about using them?
What exactly does "buffing" and "non-buffing" mean. I know it has something to do with the finish, does buffing just mean using polishing compound?
Anything else i should know about MM metalizer paints?
Old 12-26-2005, 03:51 AM
D_LaMz's Avatar
D_LaMz D_LaMz is offline
Re: using model masters metalizer
need an airbrush
Old 12-26-2005, 03:58 AM
i have a Paasche VL
Old 12-26-2005, 04:20 AM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
I never heard non buffing
so (like in your bottle's instructions) just spry trought AB, paint is already thinned, do a couple or three layer
wait 10/15 mins, paint become almost matt
buff with a soft cloth, cotton, ecc: tone should become pretty "true metal look"
seal with modelmaster sealer
after you could carefully done some washing/drybrushing
this's what i know, non-buffing seem to me like a normal metalized color, so I think it's need to be clearcoated like all metalized.
just try, good luck
gio
Old 12-26-2005, 04:22 AM
gionc's Avatar
Authorized Vendor
just a little thing: warning for metalizer smell: awesome so turn on your sprayboot&run
gio
Old 12-26-2005, 05:15 AM
Lambo003's Avatar
Lambo003 Lambo003 is offline
As gionc said, spray buffing metalizers and let dry, use a soft cloth to buff the finish.
Non buffing require just that, no buffing.
Using the metalizer sealer on either will greatly diminish the metal sheen. It's recommended that you only use the sealer in areas where the finished model will be handled. Since the uses of metalizers in automotive subjects are rarely handled, you can forego the sealer. It's really meant for finishes used on aircraft where handling is usually done on the fuselage and such.
Chuck
Old 12-26-2005, 11:23 AM
gionc's Avatar
Authorized Vendor
you're right: I also observed that sealer decrease "real metal appeal" and shine. Also this paint is really fragile w/out clear
gio
Old 12-26-2005, 12:37 PM
Layla's Keeper's Avatar
Layla's Keeper Layla's Keeper is offline
Supermodified
I'll add to the sealer comments that a good substitute for the sealer is a solid lacquer dullcote like Floquil's or Model Master's.
Also, if you really don't want a top coat over the metalizer (which most folks don't since it can spoil the look) then use a good "tooth" lacquer primer (like Floquil or 3M automotive) that the metalizer will stick to.
Proud Owner/Operator of Haven Raceway and Hobby!
Old 12-26-2005, 11:17 PM
klutz_100's Avatar
I'm pretty sure this is a dumb question, but I'll ask it anyway
If the MM sealer dulls the metal finish, could you use acrylic gloss clear (X-20?) instead? This could be polished after. Or could you mix the metaliser and clear before spraying? Would this make it more robust? Has anyone ever tried this?
I've had too much Christams spirit, perhaps?
Old 12-27-2005, 03:24 AM
gionc's Avatar
Authorized Vendor
Re: Re: using model masters metalizer
do you mean to mix sealer and x20?
I don't know exactly how kind of enamel MMM should be, MM sell a kind of thinner, However sealer is extremely thin, also if you do 2/3 layer when youtry to polish it is easy to come down to the tint
where'is my english from Christmas?
gio
Old 12-27-2005, 03:33 AM
klutz_100's Avatar
Re: Re: Re: using model masters metalizer
Yes, something like that. I was just "thinking out loud"
MMM and clear would need to be compatible for sure. I was wondering if sealer could be replaced with smthg else or even pre-mixed with the clear.
My English is the bottom of a bottle
Old 12-27-2005, 05:06 AM
Lambo003's Avatar
I don't recommend mixing metalizers with anything. Their make up is totally different than that of regular hobby paints, even if by Testors.
A dullcoat will still affect the metallic sheen as will a gloss and it just won't look like natural metal. Sure it's a delicate finish but, it's not THAT delicate. Just be aware that you're handling it and it will be fine.
On the flip side, I've found the use of a dull coat on the aluminum metalizer will leave you with a nice oxidized aluminum "look" found on many engine castings.
Also, brushing metalizer is almost impossible because they are so thin. I purposely store mine upside down so the metallic's will settle in the cap. When you remove the cap you will have a nice mound of metallic pigment ready for brushing (just don't shake the bottle too much before opening).
Chuck
Old 12-27-2005, 09:05 AM
gionc's Avatar
Authorized Vendor
eh eh uside down: great tip man, I need to try, good for tuch up..
gio
