Old 12-26-2005, 12:04 AM
badgerraf badgerraf is offline
Throttle Position Sensor and Misfire
Not sure if I have two different problems here. But I have a 1997 GP GT with the 3800 series and it has begun to misfire at idle. It does this sparatically once it has warmed up and it is just sitting at a stop light. It kicks on the Service Engine Soon light and I read the code on it and cylinder two is acting up. It also says there is a problem with the throttle position sensor. I was planning on new plugs and wires anyways, but could the sensor also have something to do with the misfiring? I understand the concept of the sensor, but how important is it and how does it work? Do you think I have two seperate problems here? Thanks
Old 12-26-2005, 06:56 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Throttle Position Sensor and Misfire
Definitely tune it up, including plugs, wires, pcv valve and fuel filter. Have the codes cleared and if the TPS code comes back, you may have an issue with the TPS, but that could be a ghost code caused by the misfire.
Old 12-26-2005, 09:36 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Re: Throttle Position Sensor and Misfire
A misfire will not cause a "ghost" TBS code.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-26-2005, 09:42 AM
GMMerlin's Avatar
I know stuff
I think you are looking at 2 seperate problems.
Since you have a cylinder specific misfire, I would start there.
Possibility of ignition or fuel related. I would start with ignition because that is the easiest .
You can start by swapping plugs and wires and see if the misfire goes away.
In my experiance with an idle misfire, I would look towards the fuel system (possible lean injector).
With the TPS, it is an important imput to the PCM It is a simple 3 wire potentiometer and diagnosis is fairly straight foreward.
The important thing was the code..was it a performance, low or high voltage code?
GM WCT
PM Me for details
Old 12-27-2005, 12:55 PM
It was P0121 Throttle Pedal Position Senson/Switch A Circuit/ Performance Problem. It then says that the computer senses a problem with the throttle circuitry. I agree that I should start with ignition and the cars due for new plugs and wires anyways. The misfire is not continuous so it may be more difficult to pinpoint. I'm not sure if this matters or not. Thanks
