Go Back   Automotive Forums Car Chat > Mitsubishi > Montero/Shogun/Pajero
Old 12-25-2005, 10:16 PM
hclayjr hclayjr is offline
2000 Montero Sport interior outlets cause horn to sound
I have used the interior outlets for the past 2 yrs w/o incidence. I have used a coverter as well for a small TV on long trips. Now, if anything is plugged into the outlets the horn sounds will not cut off until the fuse is pulled. How do I fix this problem?
Old 02-24-2006, 03:37 PM
badeauxc badeauxc is offline
Re: 2000 Montero Sport interior outlets cause horn to sound
Re: F A Q- Updated 12/19
« Reply #5 on Dec 19, 2003, 3:18pm »Q- The wierdest thing started to happen to my truck recently....when I plug something into the 12v access outlet like my cell phone charger, the horn starts goes off and stays on until you shut the engine off or take out the keys. What is causing this?
A- The problem is caused by a blown fuse (of all things). Power is backfed to the theft alarm horn once an accessory plug is installed into the outlet. It can also be caused by a coin or something metal falling into your accessory plug outlet.
The fuse is not in any of the standard locations (engine compartment and drivers side kick panel). Rather, it is located behind the drivers side knee bolster near a bunch of relays and is covered by a black cap. The picture below show a generalized location of where the fuse is located (underneath the drivers lower knee dash area). It may be in a slightly different location depending on model, though they are still covered with a cap. Just replace the blown fuse and this should solve your problem.
Copied from
http://msport97.proboards6.com/index.cgi?board=faq&action=display&thread=10933814 55&page=1#1071865108
