Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 12-25-2005, 03:38 PM
jnn7404 jnn7404 is offline
Bad fuel pump?
Hi,
I got my fc to crank but it will only run if i spray starter fluid into the intake. My fuel pump isn't making any noises so maybe that is it. But there is four wires going to the pump and the previous owner put a toggle switch on the black/white stripe wire. I don't know why he done that because it is only a ground wire. Does anyone know why he would do that? Also i tested the red and blue wire for power but neither one tested positive? Do you think it might be the ecu or should i replace the pump first? Any help will be a huge help.
Thanks in advance
jnn7404
p.s.
It's an 87 non turbo sat for a long time.
Old 12-25-2005, 11:46 PM
fcdriver fcdriver is offline
Re: Bad fuel pump?
I would start off by checking all the fuses and trace the power wires to the toggle switch to make sure nothing is unhooked or blown, then if everything checks out ok pull the fuel pump acces cover off in the rear of the car under the carpet and check for voltage there.
Originally Posted by dampachi
Violence isn't always the answer..but sometimes..depending on the question..it can be the answer.
Old 12-26-2005, 08:51 AM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
Re: Bad fuel pump?
and while youre there replace fuel hoses and pulsation damper, you dont want those to leak
RX-7 TII
