Go Back   Automotive Forums Car Chat > Volkswagen > GTI
Old 12-25-2005, 03:26 PM
bmossa bmossa is offline
Send a message via AIM to bmossa Send a message via Yahoo to bmossa
gti 2002 1.8t teptronic
hello
i found out why it was shifting hard, the wire that connects to the transmission was cut, i had to go one by one to find that problem, very time consuming, but i still have the other problem, its stuck on 4th gear sometimes, but it drives normal when its cold, all of a sudden it goes to 4th and stays there until it cools off i guess, any ideas as to why, thanks
Old 12-26-2005, 09:29 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: gti 2002 1.8t teptronic
check the rest of the harness / sensors. Some of the speed sensors have a long wire before it connects to the main harness. Where was the wire cut?
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 12-26-2005, 10:32 PM
Re: Re: gti 2002 1.8t teptronic
The wire that is cut. goes to the transmission, lots of wire in the whole bunch. right next to where you fill up transmission with oil.
so your are saying that it might have something to do with wires still, but it drives normal, then all of a sudden it goes and gets stuck on 4th gear. what u thnk
Old 12-30-2005, 08:02 PM
VDUBMAN
Re: Re: Re: gti 2002 1.8t teptronic
well saying you had a wiring issue its hard to say if its still. And since i dont know where the wires go to that were damaged I cant say what its for. If you could take a picture or something it would help.
Old 01-02-2006, 06:07 PM
Re: Re: Re: Re: gti 2002 1.8t teptronic
I ran a test and it showed that it was shift timeing is off, or malfunction, how can that be fixed? thanks again
Old 01-03-2006, 09:03 PM
VDUBMAN
Re: Re: Re: Re: Re: gti 2002 1.8t teptronic
what do you mean ran a test and shift timing is off?
Old 01-03-2006, 09:14 PM
Re: Re: Re: Re: Re: Re: gti 2002 1.8t teptronic
connect a computer and it said shifting malfunction, shifting timeing is off,
