Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 12-25-2005, 03:04 PM
atv087 atv087 is offline
Send a message via AIM to atv087 Send a message via Yahoo to atv087
supercharger on 3800 engine 1992
what kind of mods would i need to do to mount a super charger on my 1992 oldsmobile eighty eight royalle?? id like to do it as a project and i can obtain one from a junk yard
thanks jay
Old 12-26-2005, 01:34 PM
Ofnarcr Ofnarcr is offline
You pretty much cant unless you get a supercharged 3800 swap. Somethin about the intake or something being different.
Old 12-26-2005, 04:38 PM
turtle_time85 turtle_time85 is offline
Send a message via AIM to turtle_time85 Send a message via Yahoo to turtle_time85
Re: supercharger on 3800 engine 1992
If you find out how to do it and about how much. I am intersted. I have been hoping to put on in my 1997.
Old 12-29-2005, 01:56 PM
yea i got a feeling i have to swap the motor
Old 01-02-2006, 05:28 PM
razr_88 razr_88 is offline
Send a message via Yahoo to razr_88
Re: Re: supercharger on 3800 engine 1992
the reason you can't put a supercharger, or a turbocharger is because the fuel regulator runs on a negative pressure just before the intake manifold... i think
Old 03-27-2006, 08:54 PM
Tuni Tuni is offline
Send a message via AIM to Tuni
I can't be absolutely positive on this, but I don't think you would necessarily have to swap the whole engine, just the intake manifold and belt. The engine block from a 92 3800 should be the same as later models, or at least real close, since both were series I 3800's. I don't think they used the series II's for the supercharged engines at first but I could be wrong.
Old 03-28-2006, 01:18 PM
tri-power's Avatar
tri-power tri-power is offline
You should also investigate wether or not the computer is set up to work with it. Also check to see if you need to change the injectors to a higher pressure injector for compensation.
Old 03-28-2006, 01:49 PM
it would be alot more difficult to do that id rather just do the whole motor and tranny swap. and then swap the whole wiring harness and computer. it would take alot less time than changing the heads and exhaust and then have a custom computer made for it to work.
