Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 12-25-2005, 12:14 PM
Newmanb Newmanb is offline
CR-V keyless entry install
Hi...just got a keyless entry for my 2004 CR-V...not sure how to install...I have a small black box and 2 remotes....any help much appreciated!...Merry Christmas
Old 12-25-2005, 12:54 PM
dean,can dean,can is offline
Re: CR-V keyless entry install
the install for your keyless entry /what make is your keyless entry if your keyless entry is _neg inputs just have to tap into the wiring and power up the unit. merry christmas also.
HONDA
MODEL YEAR(S)
CRV 2004 -
KEY T-HARNESS IMMOBILIZER
N/A N/A HONDA'S TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY
PART COLOR LOCATION
12 VOLT CONSTANT WHITE (+) IGNITION SWITCH HARNESS
STARTER BLACK/WHITE (+) IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 BLACK/RED (+) IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 WHITE/RED (+) IGNITION SWITCH HARNESS
KEYSENSE N/A
PARKING LIGHTS ( - ) BLUE (-) @ FACTORY ALARM Plug, See NOTE *2
PARKING LIGHTS ( + ) RED/BLACK (+) @ BACK OF FUSEBOX, TOP MIDDLE PLUG
POWER LOCK WHITE/BLUE (TYPE B) @ DRIVERS DOOR HARNESS
POWER UNLOCK WHITE/GREEN (TYPE B) @ DRIVERS DOOR HARNESS
DOOR TRIGGER GREEN (-) and LIGHT GREEN/RED (-) Use both, See NOTE *1 @ FACTORY ALARM PLUG, See NOTE *2
DOMELIGHT SUPERVISION GREEN/RED (-) BACK OF FUSEBOX
TRUNK RELEASE BLACK/YELLOW (-) @ HATCH RELEASE SWITCH
SLIDING POWER DOOR N/A
HORN ORANGE (-) @ STEERING COLUMN HARNESS
TACH BLUE @ 2-PIN CONNECTOR, BEHIND BATTERY
WAIT TO START LIGHT N/A
BRAKE WHITE/BLACK (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM DISARMS with FACTORY REMOTE CONTROL ONLY!!
ANTI-THEFT TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY TRANSPONDER @ IGNITION SWITCH TUMBLER
EXTRA INFORMATION
NOTE *1 THE DRIVERS DOOR TRIGGER IS GREEN (-),AND LIGHT GREEN/RED CATCHES ALL OTHER DOORS. WHEN CONNECTING TO AN ALARM SYSTEM, USE BOTH DOOR TRIGGER WIRES AND DIODE ISOLATE, TO CONNECT, See DIAGRAM, NOTE *2 THE FACTORY ALARM PLUG IS LOCATED TO THE LEFT OF THE STEERING COLUMN IN A GREEN PLUG.
Old 12-25-2005, 04:39 PM
I have a CR-V with no original remote keyless entry and trying to add one would like to know where the green plug is located to plug this new unit in. The unit is the factory honda keyless entry module. Sorry for the confusion on my part of the posting.
