Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 12-25-2005, 12:10 PM
SLOWnSTEADY SLOWnSTEADY is offline
is this turbo too big for my application?
OK i am getting ready to finish up my 3.4L DOHC in my 1987 fiero. this is the specs of the turbo i will be using. does it seem to be a good size? i have been told it may be a little big.
the engine is a 93 with 94-95 cam carriers running on a 94-95 ECM and harness. has P&P heads, intakes, TB and ported exhaust manifolds. also has a 255LPH fuel pump, and 36# injectors. i will be running a constant 8psi daily and prolly turn it up to 12 or so at the track.
SPECS:
.66 A/R cold
1.05 A/R hot
Turbine Wheel:
Exducer: 3.05"
Major : 3.46"
Compressor Wheel:
Exducer: 2.56"
Mayor : 3.90"
Old 12-26-2005, 08:46 AM
65Shelby427 65Shelby427 is offline
Send a message via MSN to 65Shelby427
jeezus tap dancing christ...thats huge!
As a suggestion.....i have one word for you-LAG. dependent upon the backpressure of these manifolds of yours, i could see your lag being huge-i'm talking 5 to 7 and a half seconds. move on down to a much, MUCH smaller turbo-or you wont end up using it until 4 and a half to 5 thousand RPM. sorry to burst your bubble.
Mike
Old 12-26-2005, 12:58 PM
garret_the_driver garret_the_driver is offline
Send a message via AIM to garret_the_driver Send a message via MSN to garret_the_driver
Re: is this turbo too big for my application?
Sounds like a drag turbo, but I don't anything about the specifacations of turbochargers.
"Does it really matter what you drive? Import or domestic, Inline-4 or V8, just have fun. Because in the end, after all the money you've spent and time you've put into it, driving is what it's all about."
FORUMS SHOULD NOT BE CENTERS FOR FLAME WARS!!!.
Old 12-26-2005, 01:05 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
on the garrett turbocharger page somewhere i think there's a pdf that shows the roper size of turbo for various engine sizes at various boost levels. i think the site is http://www.egarrett.com just look around the page and you might find it, i haven't been in a while so i don't remember exactly where it is.
