Go Back   Automotive Forums Car Chat > Geo > General Discussion
Old 12-25-2005, 11:28 AM
jamesmetairie jamesmetairie is offline
94 prizm differential question=
from the get go i,ve been getting alot of steady noise while driving. question = if the dip stick for the a/t says it,s ok, can the differential level be low?? if you lose a little a/t fluid daily could it be some thing coming out of the differential? is it possible to spring a leak there? a/t dip stick says refer to repair manual about differential level. if i run the car up on a ramp for oil change can i access the differential check level plug?thanks for any help.
Old 02-01-2006, 04:42 PM
motu 56 motu 56 is offline
Re: 94 prizm differential question=
The steady noise that you are hearing could be CV joints. Please note that the differential and transmission are separate units. A trans mechanic told me that many GEO Prizms fail due to low Differential fluid.
Old 02-01-2006, 05:11 PM
yes, i found out these cars lose a/t fluid from the differential area. you will see it on the driveway. but your a/t dip stick will appear correct level. you must check the level of the fluid in the differential seperately. the differential holds the fluid separate. it does not circulate through the a/t into the differential. on my a/t dip stick it tells a story. it says refer to shop manual to check differential level.anyway thanks for the help. i,m selling this puppy soon.
