Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 12-24-2005, 11:38 PM
graygoose graygoose is offline
Driving without overdrive will save gas?
If I Drive without overdrive will I save gas? and if I turn traction control off will I save gas? thanks.
Old 12-26-2005, 12:32 AM
Indy8's Avatar
Indy8 Indy8 is offline
Re: Driving without overdrive will save gas?
There is no overdrive, and traction control only pulses the brake caliper of a slipping/spinning wheel.
Quality isn't expensive, it's priceless.
Old 02-17-2006, 08:51 PM
kiway22 kiway22 is offline
Send a message via Yahoo to kiway22
Wink Re: Driving without overdrive will save gas?
If you want to save gas. Then you know the drill: No jack-rabbit take-offs, Proper inflated tires, Premium gas(best in the long run), leave racing to Nascar, try to do more in one trip(as most women will tell you, when you go shopping, make a list), and do your mantenaince(oil change, plugs, coolant, air filter, etc..) on time.
Old 02-17-2006, 09:46 PM
tjm's Avatar
tjm tjm is offline
yup - that'll do it. cruise control at 65 on the hiway or less if you have time and don't mind people swearing at you.
another trick is to use the break as little as possible; it actually helps you let off the gas sooner so less waist.
27.2 hi-way - 1997 with 208,000 miles
'97 Majestic Teal Metalic, 233,000 miles of smiles
Member of the AURORA CLUB OF NORTH AMERICA
