Go Back   Automotive Forums Car Chat > Chevrolet > Nova
Old 12-24-2005, 10:07 PM
harleygolf1 harleygolf1 is offline
70 nova brake problems
I have a 70 nova w/ drums all around. When I push the pedal it feels like I am pushing a boulder, it is just hard as a rock. Has anyone encountered this problem before?? Any suggestions?
Old 12-26-2005, 01:29 AM
AlmostStock's Avatar
AlmostStock AlmostStock is offline
Re: 70 nova brake problems
When you apply the brake how far does the pedal travel before it gets "hard as a rock"?
Mark's Garage est. 1983
Old 12-26-2005, 09:25 PM
Re: Re: 70 nova brake problems
almost as soon as I push it
Old 12-26-2005, 09:59 PM
The brake pedal arm has a pushrod which activates the master cylinder. Check to make sure you have a little free play (1/4 to 1/2 inch) before the pushrod starts to press the cylinder. If not then loosen the lock nut on the pushrod and shorten it as required and re-lock. Check this first and let us know what you find.
Old 01-03-2006, 08:50 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
I fell for the push rod clearance problem once on a '66 Impala, never forgot it. This is something that you do whan you replace the master on a manual brake system. The car will also be nearly impossible to move if they are locked up tight.
If you have the hard pedal problem with power brakes, the problem is with the brake booster.
Bob
