Old 12-24-2005, 09:18 PM
ritalin ritalin is offline
5 speed clutch
anyone out there know if clutch can be adjusted. i think my 5 speed clutch pedal is a little higher now than previously. i can feel and see from my tach that my clutch slips at high speed like 3000 rpm and above.
Old 12-24-2005, 09:48 PM
clawhammer's Avatar
clawhammer clawhammer is offline
Re: 5 speed clutch
You're talking about two different things. One is the engagement point, which can be adjusted by screwing around with the clutch cable. Open the hood, and have someone press the clutch in and out, and look for the cable that moves. Well, you can adjust the engament point with that.
The second is the slipping issue. If it's slipping above 3000 rpms, than the clutch is bad, and adjusting will not help. You will then need a new clutch.
2001 Honda S2000 New Formula Red
Mods:
Engine: Comptech Air Intake Box, miscellanous chrome dress up pieces
Suspension: Comptech front strut tower bar
Exterior: Grillcraft grill, lots of wax
Interior: Rick's leather console cover, Muz one-piece luxury floormats, Rick's windscreen,
Electronics/Audio: Polk speakers
Wheels/tires: 18" SSR Competition wheels with 225/40 and 255/35 tires
Old 12-24-2005, 10:24 PM
Re: Re: 5 speed clutch
if my clutch is bad..how cum it wont slip at low speed or below 3000 rpm?
Old 12-24-2005, 10:33 PM
clawhammer's Avatar
Re: 5 speed clutch
The higher in the rpms you are, the more power the engine makes. Since your clutch is worn out, it's not able to hold all the power that the engine is making, and therefore it slips.
Mods:
Old 12-25-2005, 12:49 AM
hmm ok..so do you think i should replace my clutch then? which one is better ..high performance or just regular stock clutch? i dont race but i like to drive fast sometimes..
Old 12-25-2005, 12:59 AM
clawhammer's Avatar
Re: 5 speed clutch
I'd just get an aftermarket one. Probably stage 1 or 2, nothing higher though. They will probably last longer than stock. Don't get 3 or higher because it becomes harder to slip and becomes harder to drive on the streets.
Mods:
Old 12-25-2005, 01:04 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Ive always gotten just stock replacements. theres no need for stage 1, 2.... any of that for just a stock motor that likes to be driven hard every once in a while. if youve got the money to spare, go ahead and get a stage 1 or something but its definitly not necessary.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 12-25-2005, 04:47 AM
DjMosy DjMosy is offline
Send a message via MSN to DjMosy
i totally agree - no need for stage 1 and expecially not stage 2 lets not even talk abou stage 3.
yes that is DEFINITELY a bad clutch - if its so bad that its slipping past 3000rpm then u better change it FAST or dont drive it. after a week or less of drivign on that clutch it will wear down to a point where u wont be able to go faster than 30mph revving at 7000 or go up the slightest inclined hill and ur transmission will be full of hair-like fibers from the clutch.
