Old 12-24-2005, 07:42 PM
TaurusKing TaurusKing is offline
01 Caravan question
Where can I find the carbon canister on this vehicle?? My pal's got a problem in his evap system, I'm not familiar with Dodges, thanks...
Old 12-24-2005, 08:51 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 01 Caravan question
Look under the van on the drivers side. Should look like a flat black box. Usually located in front of the fuel tank. What code did you get on the scanner. Sometimes the solenoid under the hood is a problem not the canister itself.
Old 12-25-2005, 11:53 AM
We had 2 codes, both related to evap, 1 indicated a small leak, the other a "gross" leak,, what I was reading up on it, the evap system monitor checks itself for leaks every startup, we're hoping maybe it's just something unhooked or maybe a fitting broken,, his mil light has been on for months, due for inspection now, you know how that goes,, thanks for reply, we'll check it out this week
Old 12-25-2005, 05:42 PM
Pontiac Guy
A small leak usually means a bad or loose gas cap. A code for a large leak usually means you have a loose or damaged hose or hole in the canister. Good Luck!
Old 12-26-2005, 08:49 AM
Re: Re: 01 Caravan question
Thanks for the info, we'll give it a go
