Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 12-24-2005, 04:53 PM
larryscope larryscope is offline
Alternator Light Flickering
Lately while driving, the alternator light flickers (comes on real dimly, goes of, repeat). At the same time the interior lights dim slightly. The engine runs slightly uneven at the same time.
The alterator has been replaced before. Is this the issue?
Old 12-27-2005, 05:43 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Alternator Light Flickering
There are a couple of items that can cause this. Start by checking the wiring to the alternator and to the starter, battery and power control center under the hood. If everything is clean and tight then you may want to check the belt as it could be slipping causing the alternator light to give you intermittant charging. Finally it is possible that the voltage regulator inside the alternator is going bad. I would check all the other items first since that is a long shot.
