Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-24-2005, 03:20 PM
dimitri_ dimitri_ is offline
Identify this part
I'd like to remove it to find out if it's leaking too.
Is it timing/position sensitive or can I just remove it and look for a leak?
http://www.dotp.com/eclipse1995/PC220013.jpg
Old 12-24-2005, 03:27 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Linky no worky
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 12-24-2005, 04:21 PM
Re: Identify this part
Link fixed!
Originally Posted by l_eclipse_l
Linky no worky
Old 12-24-2005, 06:39 PM
It would also help if you told us what car we are looking at, but from the picture I have no idea.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 12-24-2005, 06:52 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
The sensor with wires running to it under the little silver can apears to be a camshaft position sensor.
They usually have a o ring seal on them leak or can leak threw the wiring plug.
You will need to test for leaks with engine running.
But I am just guessing without year make and model and eng and trans and mileage and how many doors.
Like what has been asked what is it?
MT
MT
Old 12-24-2005, 07:15 PM
Re: Re: Identify this part
The car is a '95 Eclipse GS with a non turbo engine.
Camshaft position sensor sounds right since it is attached to the end of the camshaft.
As you can see from the picture there is quite a bit of oil accumulated there, and I can't tell if it was all dripping from the valve cover, or if the sensor assembly is leaking too.
The question is, before I remove it, or reinstall, it do I have to worry about camshaft position?
Old 12-24-2005, 08:24 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
I don't think so. There should be a little piece that connects inside that only fits on one way. Never taken mine off, but i think it's like that.
That little silver piece, I have no idea what that is. Been looking into that, just haven't found that yet.
Here is the cam position sensor on a model for those turbo guys or whatever that have no idea where that is. Small pic.
That is filthy dude.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 12-24-2005, 11:47 PM
Don't worry about the silver thingy. It's a suppression capacitor, it 's bolted at the front right side of the valve cover.
I'll clean it real good like and see if there is still a leak after the valve cover gasket is replaced.
Then we'll have fun with the before and after pictures
Thanks for the replies everyone.
Dimitri
