check engine light
My wifes engine light came on and after going through the engine, I can find nothing wrong and and Id like to find out how to turn it off if anybody knows any tricks on how to do this
I just had the same problem myself on my 97 stick shift RAV4. I decided to invest in a OBDII scanner ($68 at Walmart, but you see them for half that on eBay). The code was P0130, oxygen sensor circuit problem. It was really cold here in PA when the light came on, so I wondered if the fault was triggered by that. So I used the "erase" function on the scanner to turn off the light and see what happened. So far (about ten or so engine cycles), the check engine light has not come on again. I'm not at all sure the problem is fixed (but I know where to look if it comes back), but I think the scanner was a good investment (equal to one hour of labor at the shop!) that I can use on my other cars as well as the RAV.
I'd be interested if anyone has any experience with this issue? Ray |
Re: check engine light
engine light-- head light?
I too have an activated engine light and coincidentily, one of my head lights expired at the same time. has anyone had the experience that the engine light could mean it's time to check your head light? Also, if it helps, I just reached 220,000 km's. Could this be a reoutine maintenance check for something?
Thanks |
Re: engine light-- head light?
Hi Vonda: There should be no connection between your check engine light and the headlights: one coming on as the other fails really is just a coincidence, as you say. I don't think there is anything programmed to come on at a certain mileage. After nearly 150,000 miles you're probably due for some new headlights (I put 100 watt high beam bulbs in mine - now I can really see where I'm going), and maybe even some new engine management components: PCV valve, O2 sensor, etc. Worth getting someone with one of those OBD II tools to check it out.
BTW: my light has remained unlit after the reset. Must have been just an electronic spasm. Ray |
