Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-24-2005, 12:18 PM
Ellery4u Ellery4u is offline
2G ABS computer Wiring Schematics
I've searched all the forums but I have not found any listings for wiring schematics for the ABS computer. My ABS light is on and the code says there's a open circuit on the Right Rear Speed sensor (Code 13). I already checked the wheel sensor resistance (1.9 Kohms - even though the Chilton manual spec says 1.0-1.2 kohms). I also put a scope on the sensor to check and the sensor reacts fine with 1 full wheel rotation giving me a good sine wave. I also checked for continuity upstream to the computer and it was good. I don't know what else it could be unless there's any porblems with the computer itself?
I also tried erasing the code via the DSMTuner tip of stomping on the brake pedal 10 times and it hasn't reset.
I'm at a loss and the actual wiring schematics would be a great help yet nothing I've found includes it. Does the Manufacturers' Service manual have this schematic at all. I don't want to buy it and not have it included.
Thanks for any help from anyone on this.
E
1998 GS-T currently all stock
