Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 12-24-2005, 11:18 AM
scuba4321's Avatar
scuba4321 scuba4321 is offline
how to turn of check engine light
have 1995 v-8, check engine has been on for a looong time. no codes, just passed emissions check, runs good. I am just tired of looking at that bright light! How can I turn it off, take the bulb out without having to take the das apart! Thanks
Old 12-24-2005, 11:26 AM
overl0rd overl0rd is offline
Re: how to turn of check engine light
There have to be codes if the MIL is on. If you seriously get no codes out of it then there is a fault in the light circuit
Old 12-24-2005, 09:16 PM
scuba4321's Avatar
Re: Re: how to turn of check engine light
true, but I just want to know how to shut the light off, I do not want to have to use black tape!!! lol
Old 12-25-2005, 12:02 AM
Re: Re: Re: how to turn of check engine light
If you unhook the negative battery terminal for a minute or so it should lose the fault in memory thats causing the light to be on.
Old 12-25-2005, 01:05 PM
melfan melfan is offline
Want a shade tree mechanic fix?
Drop the dash and pull the bulb. Problem solved!
Old 12-27-2005, 11:10 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
I have the same problem with my airbag light. The computer will make an annoying beep sound if you take the light out (Since its essentially tricking the computer into thinking a bulb blew) So, black electrical tape will easily fix it.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 12-27-2005, 11:38 PM
RahX RahX is offline
v8 eh? which one? the 4.6L were bad about the EGR passages in the throttle body gettin clogged up with carbon.
