Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 12-24-2005, 05:24 AM
Jesse R. Ellis Jesse R. Ellis is offline
92 Dakota dies and wont start for 5-25 minutes. PLEASE HELP!!
I purchased a 1992 Dodge Dakota with a 318. It seems to run perfect with two exceptions. The first problem is when I am on the highway. When I keep it at a consistent speed it will buck a little. It stops immediately after I start to accelerate or decelerate. The second is a strange one. While driving down the road or at a stop light the truck will just die. All the lights work, the motor turns over but it wont start for about 5-25 minutes later. It seems to do this about once a day. Because my CHECK ENGINE light never comes on it wont give any codes. So far I have replaced the fuel pump (due to a misdiagnoses by Lithia), the oxygen sensor, coil, distributor cap and the rotor. None of this helped. Please Help!!!
Old 01-06-2006, 03:56 PM
jon_norris jon_norris is offline
Re: 92 Dakota dies and wont start for 5-25 minutes. PLEASE HELP!!
i had the very same problem with mine, runing for about 10 minutes the stalling and not crankin back, and no check engine light, and i replaced the computer about 3 days ago and it runs fine now. although it could just be bad wiring.
Old 03-27-2006, 06:49 AM
slicknickel slicknickel is offline
I had the exact same problem. Down to the letter!
After replacing multiple sensors and just about striping the ignition wiring harness, I finally gave up and bought a new computer. It worked, problem solved. I have also recieved replies from several other ppl who have come to the same conclusion. BAD ECU.
