Go Back   Automotive Forums Car Chat > Honda > N2O | Turbo | Superchargers
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance.
Old 12-23-2005, 11:56 PM
92 lude man 92 lude man is offline
h23 TURBO HELPPPP
I HAVE A QUESTION>>>
Will a turbo kit from a h22 fit on an h23? 2.2L to 2.3L. I realize they are closely made and a lot of parts are interchangable, but i need to know if an h22 turbo kit will work and not totally screw my motor over. Will it work? I am the most leary about the boost issue. because an h22 puts out way more high end and a h23 is the torque monster. so maybe i could do a hybrid turbo conversion,...... PLEASE HELP ME!!!!
Old 12-24-2005, 12:14 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: h23 TURBO HELPPPP
you have no idea what you're talking about...you can limit the boost and the only issue is the actual fitment of the parts. The boost issue isn't a big deal. You should list the specs of the turbo and what the wastegate is set at.
BTW, what are you using for tuning and what size injectors are you using for boost?? Power goal??
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 01-09-2006, 01:35 AM
L8R_H8R L8R_H8R is offline
yeah i kinda had the same question. I have an h23. and am happy with it but the h22 turbos are far superior to the choices for the h23.
At the time, McLaren was racing successfully with Honda engines, and it seemed logical to approach Honda for an engine meeting Murray's requirements. But the Japanese declined, feeling that they could not spare the capacity to develop such a project.
Old 01-15-2006, 03:40 PM
skinnye skinnye is offline
Make a kit yourself its much cheaper, for fuel management you can use a po6 ecu and run uberdata, its basically a free standalone program for hondas, as well is crome, and several others, check out www.homemadeturbo.com it will help alot
Old 01-15-2006, 09:43 PM
Schister66's Avatar
AF -Advisor
im' making a DIY turbo kit....look at the sig....if anyone needs help or has any questions about certain set ups, you can add my MSN address i have listed in my profile....dont be shy!
DIY is the ONLY way to go.....much cheaper and better quality....
Old 01-16-2006, 10:40 PM
I've turbo'd my own car and helped with quite a few others and homemadeturbo is one of the greatest resources for the diy turbo guy, I'm skinnye on there as well, I could build a kit for the h23 for under $700 including everything
ex:
1g dsm turbo mani redrilled: $20
14b turbo: $100 or if you get lucky and find a good one at a junkyard $34
dsm 450cc injectors: $50
www.stealthmodeperformance.com oil lines : $70
junkyard intercooler: $4-$22
charge pipes: $100 from link above
couplers: $34
1 g dsm bov: $20 or upull it yard
1g dsm bov flange: $25 from www.tunertoys.com
air filter: $20
downpipe: $100 local exhaust shops
hose clamps and misc: $50
Old 01-17-2006, 12:05 AM
Schister66's Avatar
AF -Advisor
i'm also a member of HMT......kinda new to the site tho...been there like 2 months or so....
Stealthmode rules!
Old 01-17-2006, 12:23 AM
ex:
couplers: $34
air filter: $20
good to know, will do. thanks for the help. Unfortunetly my H23 is having major problems so it looks like im swapping with h22
Old 01-17-2006, 05:51 PM
Stealthmode rules!
its a great resource like I said and steve aka stealthmode is a cool guy and I guess you could say he is the leader of the tc crew which I'm a part of also
Old 01-17-2006, 06:43 PM
Schister66's Avatar
AF -Advisor
TC=Twin Cities?? I'm from Fargo which isn't too far away....
Old 01-19-2006, 02:40 PM
yep you should come to one of our meets sometime just search on hmt under tc crew or mn bbq, stuff like that and you'll get an idea of what we do
