Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 12-23-2005, 09:28 PM
fritz314 fritz314 is offline
Send a message via MSN to fritz314 Send a message via Yahoo to fritz314
1996 sunfire starts and dies
I have a 1996 2.4 liter manual trans sunfire. Problem is that it starts and dies. I have replaced fuel pump, fuel filter, fuel pressure regulator, plugs, ing coil pack, ign module, timing chain, plugs, ecm, map sensor, throttle position sensor, cam sensor, crank sensor, and the throttle body. The car still won't stay running any other ideas I'm about out of money and paitence for this car.
Old 01-02-2006, 05:27 PM
raycorri raycorri is offline
Re: 1996 sunfire starts and dies
Is your security light staying on or flashing?
Old 01-29-2006, 07:54 PM
The security light doesn't come one. I finally replaced the exhaust system It had a clogged catalytic converter.
Old 03-28-2006, 01:39 PM
helpmysunfire helpmysunfire is offline
So that solved the problem?? I replaced the catalytic converter on mine and it is still stalling. I posted a thread on this in hopes of getting help - I know how you feel about pouring all of this $$$ in and losing patience.
Old 12-11-2006, 05:57 PM
mttom mttom is offline
The wiring harness is very vulnerable to damage on these cars as it runs under the radiator support. if the plastic guard by the right hand computer breaks wires can be cut and scraped and can cause all sorts of head aches including an erractic fuel pump
