Go Back   Automotive Forums Car Chat > Honda > Integra
Old 06-07-2002, 03:55 PM
PFCfutrell PFCfutrell is offline
Send a message via AIM to PFCfutrell Send a message via Yahoo to PFCfutrell
Question B21 swap???
Does anyone know if any of the parts from newer B series motors will bolt up to the B21 in a '91 Prelude SI? I know it's the forgotten B series but if a B18C1 or a B16A head would bolt on or to the B21 block that would be pretty original wouldn't you think?
1991 CRX SI (black)
15.3 @ 88mph (stock motor)
'90 B18A1 swap
Custom exhaust
*2.25" piping
*two glasspacks (inline)
*polished flash-cut tip
*exits pass. side, front of rear tire.
'95 GSR 15" wheels
195/50/R15 Bridgestone Potenza SO-3's
AE Eng. front crossmember
Susp. Tech. 22mm rear sway bar
Susp. Tech. 1.8" lowering springs
Tokico Illumina 5-way adj. shocks
Powerslot rotors
Metal Master pads
Goodridge steel-braided brake lines
Red painted OEM calipers
Skunk2 short shifter
Skunk2 shift knob
GT Grant steering wheel
Red/black racing seats
Old 06-07-2002, 09:13 PM
RedRocketGSR's Avatar
RedRocketGSR RedRocketGSR is offline
Send a message via AIM to RedRocketGSR
Correct me if im wrong but i didnt think there was a B21. I've heard of the B20A5 out of the prelude tho. If it's a B series, then any B series VTEC head should bolt right up to it.
95 Integra GS-R
[email protected]
Old 06-10-2002, 10:59 AM
92 Teg-B18A's Avatar
92 Teg-B18A 92 Teg-B18A is offline
yeah, I suppose any bseries head should be able to be bolted on to any b series block in theory
92 Acura Integra RS
B18A is the bizzam
PH refugee
AF Nordic Crew #004
Warning: The Surgeon General says it's OK to smoke V-8's.
swapping 91 wrangler 4.0 for 97 cherokee 4.0 - fuel lines mismatch rykowalspt Wrangler 1 03-26-2009 05:07 PM
h23 swap 4th gen civic? 92lude91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-16-2009 11:43 AM
350 motor swap bowtieballs2000 Performance 0 03-09-2009 10:26 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
Nissan Quest V6 to 2.4 ltr 4 cylinder swap Scraped Knuckles Quest | Presage | Serena 4 02-20-2009 08:59 AM
