Old 12-23-2005, 09:29 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
water/alky injection in na vehicles
What kind of gains are to be expected in an na vehicle running alcohol or water injection?
Also, what kind of improvements can be made to the engine when on injection, not forced induction because there you can raise boost. i know you can raise compression, advance timing a bit, and it cools air so you can inject more fuel, anything else?
Old 12-23-2005, 09:43 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: water/alky injection in na vehicles
Your not really going to see any effect. Your not compressing the air so its not going to heat up any more than the ambient tempature outside.
Old 12-23-2005, 10:04 PM
but you're cooling the air down, it's just like putting on a cold air intake but it cools more than a CAI.
Old 12-23-2005, 10:29 PM
-Jayson-'s Avatar
-Jayson- -Jayson- is offline
Re: Re: water/alky injection in na vehicles
nope, the water temp is gonna be the same temp as the air temp. All its gonna do is raise your octane a bit, but that wont give you any more power.
Water injection is designed to cool a much higher air temp with the air temp water. It doesnt work for much in a NA ca, at most the intake temp might drop 1-2F, not like you will see a performance gain from that.
Unless your running high compression, this wont help you.
2009 Ninja 650 R
stock for now...
SouthEast Ecotec Enthusiast
Old 12-24-2005, 12:06 AM
are you sure? i thought that when you misted water it absorbed heat energy, what about alcohol, wouldn't that cool the intake temperature alot? top alcohol drag racers apparently have some frost on their intakes after a quarter mile run.
Old 12-24-2005, 12:26 AM
Forunn Daberator
It will lower your intake temp some but its not going to be enough to tell a big difference. Kinda like when you drive your car when its 50 degrees out and when its 90 degree, not enough differnce to take notice to.
Old 12-24-2005, 12:27 AM
kachok25 kachok25 is offline
water does absorb heat don't listen to that Jayson guy he does not know what he is talkin about, it will drop your intake temps by about 20-30 degrees depending on humidity, not enough to make any kind of huge differnece, but if you advance your timing you might see a small increase in power.
Old 12-24-2005, 12:28 AM
but you could do some things that would make noticeable improvements to performance. so i guess alone alcohol or water injection doesn't do much but it opens up more potential for the engine.
Old 12-24-2005, 12:31 AM
Not for an NA engine read my last post on my thread if you want to see what is can do for a forced induction engine.
Old 12-24-2005, 12:33 AM
the alcohol will do some good though seeing as it carries oxagen in with it.
Old 12-24-2005, 12:36 AM
Forunn Daberator
If you want to drop your intake temps get a Co2 bulb.
Old 12-24-2005, 12:37 AM
it doesn't carry enough to burn itself though, alcohol is still a fuel and you'll run rich if you can't injest enough oxygen. if it's methanol, it has one hydroxyl, it needs an extra molecule and a half of oxygen to burn. it in istelf doesn't add oxygen to the combustion chamber like nitrous oxide.
Old 12-24-2005, 12:41 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
you don't notice a huge power gain in the winter....that's all you would be similuting. Its different when it comes to turbo cars. The air is compressed and that creates heat. If you can cool the air to 90F you're doing good and that's where Water/Alcohol injection tends to help.
The Subaru STi has water injection so that the intercooler doesn't heat soak so bad....which reduces teh efficiency.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 12-24-2005, 12:46 AM
the subaru has a nozle that sprays water onto the intercooler, not into the intake, very different. anyways i already stated that it probably wouldn't be worth it unless you did something else that required lower intake temps, such as higher compression, something that would yield noticeable gains. lets say you had a 10:1 cr engine that was on the verge of knocking, raising the cr to 12:1 and advancing the ignition timing would yield noticeable gains but you would destroy your engine with detonation. if you lowered intake temps, you could do this, have the benifits of the modifications and of the lowered intake temps.
Old 12-24-2005, 01:32 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Water/Alky injection on an NA motor can have great benefits. You can increase compression on pump gas and reap the benefits of the increased tolerance that the water and alky provide. Neither will add much power, but the fact that you can run more compression with a full spark advance sure helps.
Dragging people kicking and screaming into the enlightenment.
