Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 12-23-2005, 07:13 PM
sdog882007 sdog882007 is offline
oil with sparkplugs
hey guys another question i just went to change my sparkplugs, and i pulled the whole assembly off of the first one, and there was a lot of oil in there i have read that a lot of early LS's do this (this one is a 2000) but what do i do to correct the problem? do i just tighten down the plug and hope it doesn't do it again or what?
Thanks for your advice
Steve
Old 12-24-2005, 09:48 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Either poorly seated rings or the spark plug gaskets on the valve covers are bad. Tightening the spark plug wont do anything. If its that loose to begin with, your gonna major driveability issues since your losing compression.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 08-05-2006, 02:05 AM
mopar440man mopar440man is offline
Re: oil with sparkplugs
i had this problem had to replace the o ring gaskets on the valve covers if you do them do both sides
