Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 12-23-2005, 05:10 PM
jayhawk714 jayhawk714 is offline
1996 Isuzu Trooper window
The power window on my Trooper will not close. I opened it and it opened normaly but now will not close. All of the other wndows work fine. What do you think, motor in the door or the switch?
Old 02-16-2006, 08:09 PM
kdkool kdkool is offline
Re: 1996 Isuzu Trooper window
i had this problem long ago. If you have a continuity meter, you can check the wiring traces on the switch. It was barely visible, but for some reason, there was a hairline crack that caused the switch to intermittently work. if u flex the board a bit, u could see the connection go down. I soldered another wire on it and it works great.
Old 03-17-2006, 03:10 PM
josh ashley josh ashley is offline
Send a message via AIM to josh ashley
im not positive but you should hear a click when you push the window button, if you dont then it could be a wiring problem. hope that helps.
