Old 12-23-2005, 05:04 PM
transgta transgta is offline
klunk on takeoff
My 01 supercrew when i take off i feel a little klunk but not hard or loud.It just seems like from the tranny back to rear end there must be some play in something. I did take driveshaft out and change u joint on front of driveshaft. After putting back in didnt seem to do it at first. Now its back sometimes when i hit brakes kinda hard at stop when i let off brake it does it to. Didnt know if i should change rear u joint cause these r not fun to change unless they r bad dont wanna do it for nothin. Gimme some advice THANKS DAVE
Old 12-27-2005, 08:22 PM
Re: klunk on takeoff
no one knows?
Old 12-28-2005, 07:59 PM
bumthumb bumthumb is offline
Check your universal joints for play.
Might also be excessive lash in the rear gears.
Good luck, bud!
Old 12-28-2005, 08:02 PM
Also try and coast down a hill, if you have a standard, clutch in and the out and give gas and see if clunk shows. sounds like universal.
Good luck, bud!
Old 12-29-2005, 01:46 AM
cso18 cso18 is offline
Do you have a two piece driveshaft? My old 70 F100 did the same thing. The problem was in the splines where the two shafts joined in the center. Over time, a small ridge developes in the splines causing them to bind. I heard GM had the same problems and sells a special lubricant for about $35. I found that Mercruiser U-joint & gimbal bearing grease works quite well, is much cheaper, and comes in sizes to fit most grease guns.
Old 12-29-2005, 03:33 PM
My driveshaft is one piece with a u joint on front and rear. Think ill try the rear u joint and hope thats it not gonna do it til sat so if anyone has anything else please type Thanks bumthumb and cso. for your reply
Old 12-30-2005, 03:46 PM
cajunwolf cajunwolf is offline
i had the same problem on one of my truck and found out later it was the anti locking brakes engaging
Old 12-31-2005, 12:25 PM
cajunwolf how did u pinpoint it and what was the fix?
Old 12-31-2005, 05:18 PM
Mrpiggy52 Mrpiggy52 is offline
What motor and trans is in the truck? You might check the tranny mount bolts. These stripped out of my 97 and had to redo them. Made that same kind of noise. You might also check on the exhaust manifold where it conects to the rest of the pipe.
Mrpiggy52
