Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 12-23-2005, 01:10 PM
kachok25 kachok25 is offline
High CR effect on boost
We all know that high CR are not the best thing to run with a turbocharger, but assuming that you can prevent detonation would a higher CR engine make more power than a low CR engine with the same amount of boost? Yes I know you can run more boost in a lower CR and that will more than make up the difference, but given the same pressure can the high CR make more power?
Old 12-23-2005, 01:26 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
Re: High CR effect on boost
yes, a higher compression ratio will make more power than a low compression ratio on the same ammount of boost if you can suppress knock without retarding timing and stuff.
it's just like increasing the compression ratio on a n/a car but there's more air in the combustion chamber.
Old 12-23-2005, 11:38 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
the problem w/ higher comp is that you have less control over ignition when you start getting into higher boost because the air might start igniting itself rather than the spark plug doing it.....much like a diesel.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 12-23-2005, 11:41 PM
otherwise known as knocking, which he stated was not involved in this question. he was just asking if, all things remaining equal, an increase in compression ration will yield an increase in power.
one more thing, it will also decrease turbo lag
