Go Back   Automotive Forums Car Chat > Nissan > Quest | Presage | Serena
Old 12-23-2005, 07:51 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Question A Heated Question
Ok, nevermind the pun in the subject... I know it was bad, but it was simply meant to catch your attention...
I've got a friend of mine who has a 95 Quest... the VG30E engine... this van overheated the other day on the freeway... now, I replaced the thermostat (no water seemed to leak out when I opened the thermostat housing, is that odd?)... I replaced the thermostat (that was definitely a problem)... and then I proceeded to refill the coolant system... with water for a test... No leaks, no pump noise, nothing... everything seemed fine until the van had run for a/b 15mins... the thermometer went all the way back up to H and there was no heat coming through the heater system... We tested the radiator... on the left side (looking at engine) we pulled the hose from the radiator, there was steam... I'm assuming this is the hot side...
We replaced that hose and went to the other side, we got nothing... I'm assuming this is the "cold" side... crazy thing was, I coud pop the radiator cap while the van was HOT... the cap was cold, no overflowing nothing...
I'm assuming there's no flow through the radiator... there are no holes in the radiator... no leaks anywhere... but no flow... I don't really know what to do other than flush the system (I intend on doing this anyway)... but I want to make sure the problem is corrected before spending the time/money to flush it... any ideas, and am I correct on the hot and cold side?
P.S.- The reservoir filled up when the van overheated on the Highway... it hasn't gone down since... no higher, no lower... even when we ran the van again a few times... this puzzles me...
but I'm pretty set on there being no flow through the radiator... b/c I just ran into that problem on my car...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 10-31-2007, 11:39 PM
paul allain paul allain is offline
Re: A Heated Question
probably have a blown waterpump, no flow equals waterpump defective. or major blockage somewhere in the system.
Old 11-01-2007, 10:01 AM
chubbybubba1 chubbybubba1 is offline
I'd pull the radiator and take it to a shop and have them boil it out and test it. Or like the other poster, the waterpump. Or you have a pocket of air caught in the system now after your repair atempts. Air will overheat that system just as fast as a failed waterpump or blocked radiator passage.
Old 11-03-2007, 07:35 PM
jiri41 jiri41 is offline
After replacing the thermostat the best thing to do is fill with water put the radiator cap and let the engine run until warm or thermostat to open let engine cool down and refill usually a lot more water will go in.
