Old 12-23-2005, 06:20 AM
frehol frehol is offline
Question Front diff seal change
Hi,
Can anybody tell if it is a hard jobb to change the seal on front differential left driveshaft on a -95 4wd V6CPI? It is leaking...
How much is it to remove?
Thanks,
Freddy
Old 12-23-2005, 09:14 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Front diff seal change
Originally Posted by frehol
Hi,
Thanks,
Freddy
Are you talking the seal between the transfer case and the tailshaft? If so it's not a difficult job.
Old 12-27-2005, 12:44 AM
Re: Re: Front diff seal change
No, it's the seal on the left side of the diff, on the shaft that drives the left front wheel...
Old 12-27-2005, 05:19 AM
rlith's Avatar
Re: Re: Re: Front diff seal change
Ahh...shoulda paid more attention to your first message... It's not that difficult, just time consuming. You'll need a bench and a press to get the prop shaft out. At that point a regular seal remover or hammer and a screwdriver will work to remove the seal. Use an oversized socket and a hammer to install the seal... And tap the yoke for the front prop shaft back into place...(For all this you will have to split the transfercase open. You will need a new gasket for that.
Old 12-27-2005, 07:49 AM
Re: Re: Re: Re: Front diff seal change
If I understand you right I have to remove the front diff/transfercase and splitt it in order to get axcces to the seal? It's not possible to reach it from the outside then... bummer
Sounds like a little more work then I expected.
Thanks for your replys, rlith.
/Freddy
Old 12-27-2005, 07:54 AM
rlith's Avatar
That's pretty much it in a nutshell
