Old 12-22-2005, 08:47 PM
JCL82 JCL82 is offline
Question/problem about my daytime running lights.
Alright here's the problem. Somedays my passenger side daytime running lights won't work. I first found out it wasn't working when i was in traffic i got behind a vehicle and seen it wasn't working. So i was going go to autozone and pick me another one. I check to see if the driver side one was working ,and i seen the passenger side daylight running light was also working now. Now today it did it again. Here's my question though, everytime i drive around town i see other silverados with the same problem. the passenger side will be out and the driver side will be working. Tomorrow i'm going see if it's going come back on, if it doesn't , what kind of bulb do you guys recommend ? Also if it comes back on what's your take on the problem ?
Old 12-22-2005, 08:50 PM
RahX RahX is offline
Re: Question/problem about my daytime running lights.
could be the filament in the bulb re-attatching itself so it works again. take the bulb out and give it a rattle, see if teh filament comes loose. anyway i think GM has some heavy duty bulbs for em. otherwise there should be a number like 1174 3157, somethin like that 4 digits. go to az and get another or take the bulb with you.
Old 12-22-2005, 10:17 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Honestly, I recommend you pull both bulbs and forget about them... that or some silverstars.
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 12-30-2005, 03:18 PM
LNimoy LNimoy is offline
The Daytime Running Lights are 3157. silverstars are $20 from most places. check out ebay for more options. I just got a set of Xenon white/blue Hi and Lo beams for $20 shipped. and looking at a set of white DRL for 12 shipped.
Im may just pull out the DRL and leave them out. But I was thinking would it leave a big opening in the back of the headlight that would let in moisture and make the light look nasty.
Old 12-30-2005, 04:28 PM
jethro_3's Avatar
jethro_3 jethro_3 is offline
I put orange bulbs for my '01 in place of the drl and I had the pass pop 3 times. Then I dried out the lens and sealed the socket to the lens and never had problems again.
Just my
"The Sleeper" '05 6.0L VHO
Cam in and
Low 14's happening at the track
Check out my Ride
