Old 12-22-2005, 07:25 PM
Werm9 Werm9 is offline
Broken Bulb
i just noticed my bulb harness was ripped out from my rear passenger reverse fog ligh at the bottom of the fender today. the bulb is broken. how do i remove it w/o cutting myself so i can replace it?
2001 Grand AM 2.4L 15,000 Miles
Old 12-23-2005, 12:58 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Broken Bulb
unhook the battery and use needle nose plyers. May want some safty glasses to keep flying glass chips from your eyes. That would really suck! Remember Safty first! lol
1999 Grand Am SS 3.4 OHV
Old 12-23-2005, 03:25 PM
Hoags's Avatar
Hoags Hoags is offline
Re: Broken Bulb
If Xero's idea does not work and there is glass left on the bulb you can unhock the battery and then try a piece of apple, just smash the apple into buld glass and then remove the bulb. replace the bulb and reinstall. Bellieve me...it does work Ive done it in the past. the only problem is if the bilb is corroded in ti the scoket. Let us know.
Old 12-23-2005, 10:40 PM
Re: Broken Bulb
ya. i was thinking of using a potato. i got it off. found out the manual has the wrong size bulb in it. it was much bigger than what i pulled out of the wiring harness. now i just need to find out how to change my fuel filter without a jack.
Old 12-24-2005, 08:35 AM
Re: Broken Bulb
the only reason i didnt say the potatoe trick is all that potatoe juice getting into the socket isnt good, it'll cause corrosion if not cleaned out of the socket.
Werm9, you should be able to change you fuel filter by laying under the gas tank head first, or is your GA lower'd? I couldnt tell from ur sig. I changed mine this way a couple times.
