Old 12-22-2005, 05:09 PM
Cbierniat's Avatar
Cbierniat Cbierniat is offline
Coolant
Low Coolant light only comes on when i first start my car when its cold within the first 10 mins and then it goes off...wheni had my car tuned up they added coolant which was 2000 miles ago??
Old 12-22-2005, 05:41 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Coolant
May be a bad or corroded sensor as they do get gunked up periodically. Keep tabs on the coolant to make sure you are not losing any. Sometimes coolant loss can be caused by a bad line to the reservoir or a cracked reservoir. Check this line and also you may want to replace the radiator cap just to make sure it is not bad.
Old 12-22-2005, 11:23 PM
Cbierniat's Avatar
Re: Coolant
yah im gettin a lil sick of dumpin money into this POS i love GTPs but this one is costin me a lot lately soon as i fix one thing another goees wrong
Old 12-22-2005, 11:25 PM
Cbierniat's Avatar
Re: Coolant
Ill check the sensor tomorrrow along with replacing the pVC and if that doesnt fix the miss ill try the fuel filter wheres that and how hard of a job is that???
Old 12-22-2005, 11:39 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Re: Coolant
Easy job. See link below:
http://www.pfyc.com/supportfiles/gasfilter/
Timeslip 08/12/06
AF Community Guidelines
Old 12-22-2005, 11:43 PM
mike561 mike561 is offline
Re: Re: Coolant
I know EXACTLY what you mean, same wit mine, just dumped more money into my GTP as well, had an oil leak and front axle had some kind of grease comming out of it and was causing a real bad odor
Old 12-23-2005, 08:12 AM
Cbierniat's Avatar
Re: Coolant
THank you tons!!
