Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-22-2005, 04:47 PM
ccmcgregor ccmcgregor is offline
driver lock works / the others don't work / seems if wire cut or fuse is bad?
1999 Grand cherokee
The driver door still locks and unlocks manually or by key and the alarm sets as if all doors are locked. But, the other doors or rear hatch do not lock.
I called the jeep dealer and spoke to a service writer and he said bring it in and pay $95. to tell me what is wrong.
Help me please! broke $$ with Kids.
Old 12-26-2005, 11:23 PM
vamc's Avatar
vamc vamc is offline
Re: driver lock works / the others don't work / seems if wire cut or fuse is bad?
Fuse or electrical connection.
Old 12-27-2005, 04:58 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Check the wires between the driverside door jam. Slide rubber boot over and look for a broken wire(s). Broken wires here are very common.
Old 12-27-2005, 12:29 PM
Re: Re: driver lock works / the others don't work / seems if wire cut or fuse is bad?
I believe all connections are good. I think it is a switch in the rear lift gate.
Before it quit working, the lift gate latch would make a swaack sound. as if the plastic was rubbing against a bad cog. I had researched the sound and found the switch was making the sound. and decided to waite until it went completly bad befor spending the $67. to replace.
OOPs is right. Well I replaced this switch but it still does not make the door locks work or hatch or even the right side window work either. I may have to spend the service fee. It just makes me mad to know they will sell you any thing as you ask them could this fix it they say yes . but when it does'nt oh well bring it in and we can charge you for more. Damn those dealers!!!
Old 12-27-2005, 03:45 PM
vamc's Avatar
Im with you on that one.
vamc's Avatar
Old 12-28-2005, 01:00 AM
outdoorscherokeema outdoorscherokeema is offline
I have 1 window that doesnt work and I was told it doesnt work because my master switch on the driver door is screwed up (the motor and switch on the door work fine). Could that also mess up with the locks?
Old 12-28-2005, 03:25 AM
oljeeptek oljeeptek is offline
You need to have the body computer scanned and checked for bcm codes. Could just be the relay though it's bcm controlled.
Cheap fixes do not go with 'spensive toys....
Remember...
Old Jeeps never die, they just sometimes look that way!
Old 12-28-2005, 07:14 AM
Have you checked the wiring in the driveside door jam (from the door to the body)? Might be a bad wire.
